Changing out entire engine on my 1950 H. The replacement motor has a casting code of 3*26*W on it so I'm assuming it is a 1951. Had everything on the motor but the carb and distributer and drive housing.
Went to put the distributer drive housing from the 1950 motor on the replacement motor, different bolt pattern. What the...? The 1951 bolt pattern is a little larger than the 1950. This ring a bell with anyone? Am I holding my mouth wrong and just seeing things? Was there a change in this part between the two years? If so, what part number am I looking for as a replacement if someone happens to know?
