odffirefighter
New User
Hi i am trying to get a 1953 Super M running. This is no ordinary Super M it has some old Ford truck front end. Like an F4 maybe F5 front end someone modified to give it a wide front. The front tires are shot. Easy fix right? The problem is it has split rims and of course they are the widow maker ones and no one (including me) will touch them. So i had a crazy idea this morning. If I took 1" steel plate and drill the 5x8 bolt pattern and then inside I drill a more common wheel pattern say 8x6.5" do you guys think that would hold up to normal use on a tractor? Thanks for your help, Nick
