M crankshaft cam drive gear
Lynerd
Putting a M crankshaft in the block and need to know how best to install the crankshaft gear. Better to put in on before installing crankshaft or can I install it after crankshaft in is block. Lynn
Since the gear is a fairly tight fit and has to be pressed on, I would install it on the crankshaft before you put the crankshaft back into the engine.
