F12 trans cover removal
bmagee
Needing to remove the top platform or transmission cover off my F12. What do I need to do to remove? I have all bolts out, but I think I missing something with the (4) screw looking bolts that protrude out on the sides.
Any help or guidance is appreciated
They are just pressed in dowel pins.They should
pull right out.A help,is to thread a 5/8 nut onto
the threads,'tighten.That will 'pull' the dowels
right out.
Delta Red is right. But, you will probably run out of threads before the dowels are free. Just back the nut off, add some flat washers, put the nut back on and try again. It might take two-three tries with several washers to do it.
