1952 cub tractor lights
Anonymous-0
I had generator rebuilt, replaced Voltage regulator and rewired lights. When I crank the tractor is shows fully charging, but when I turn lights on it goes to full discharge with motor running. What could be the problem making it discharge.
Wait a minute.
Before you start switching wires make sure it's actually charging. Measure the voltage on the battery with the engine running and the lights OFF. With the meter showing full charge it should read 7.0-7.5 Volts.
It is possible you have the lights wired up wrong, creating a SHORT CIRCUIT. That would cause the needle to swing to full discharge. Also your wires will get hot very quickly.
