184 engine/
bv
will the engine from a 184 cub fit in a 1957 cub tractor front pulley is a lot different also, thanks again.
Yes, it will bolt in, but there are issues.
1. You will need to change the front pulley.
2. There is no hole for a pilot bearing in the rear of the crankshaft.
#2 is pretty much a show stopper. You can't drill the hole with a hand drill, either. It must be perfectly straight, and a very specific size, so it must be done on an engine lathe.
