slifnom
I posted earlier about using Mystic Oil for engine oil. Got that , thank you. But I was rewding in the responses and I got the gist that I could use it for the transmission also! I stis righr? I had been putting hy-tran in the transmission, which is also the hydraulics, very expensive.Is the consensus I could put in the trans?Help me clear this up. Thanks guys
(quoted from post at 17:59:44 04/06/14) I posted earlier about using Mystic Oil for engine oil. Got that , thank you. But I was rewding in the responses and I got the gist that I could use it for the transmission also! I stis righr? I had been putting hy-tran in the transmission, which is also the hydraulics, very expensive.Is the consensus I could put in the trans?Help me clear this up. Thanks guys
NO!! Keep Hytran in back of the tractor.
Hydraulic Transmission Oil made by Mystic, and meeting the IH or JD standards for Hytran, or Hyguard, will be perfect in the trans, not engine oil. Jim
On a 560D I'd use Orscheln's 303 in a yellow pail. May not be as good as the current hytran brand (or it might be better) but it's a lot better than anything that was used when a 560 was new.
