Farmall H surging fix
PretendFarmer
1950 Farmall h. When I go full throttle the rpms will surge up and down. It eventually smoothed out. Is this a bad spring in the governor? If so does anyone have a source for a good one? I want to bump up the rpms a bit as well.
(quoted from post at 06:11:04 04/09/14) 1950 Farmall h. When I go full throttle the rpms will surge up and down. It eventually smoothed out. Is this a bad spring in the governor? If so does anyone have a source for a good one? I want to bump up the rpms a bit as well.
A new spring might help, but basically, that governor needs to be rebuilt.
