3414 front hydraulic pump coupling
This message is a reply to an archived post by jdemaris on August 21, 2013 at 05:46:48.
The original subject was "Re: 3414 front hydraulic pump coupling".
jdemaris, DO you have the part number for your new pump? I need a new pump and having no luck finding one. Do you know the GPM?
One part I've found that needs to be fabricated if your old one is worn. That is the cast-iron hub that bolts to the crank pulley and has rubber shock mounts on it. The splines are usually worn out. The splines are the same 7/8 X 13 that Ford, Case and Deere use. Not too hard to cut a round plate from steel and drill it and tap it to make a new coupler.
