826 international
jr1983
I have an 826 with a loader. The loader is hooked to the remotes. The loader will only raise with the three point in the up position. I put a pressure gauge in the rear remotes and with the three point up it has 1400 psi. With the three point down it has 400. Any help would be appreciated.
Are you pushing the position control lever for the 3pt ALL the way down?
There is a short section at the bottom of the position control labeled "RUN" as I recall. If you put the lever in that section it causes the rest of the hydraulics to not work.
Yes but I held a remote and slowly brought up the three point l
eaver and the loader didnt move at all till 3/4 travel of the three
point leaver. Is it possible there is somthing out of adjustment?
