200 2 Point 2 Disk Plow
LMack
I did some plowing today with my 200 with a 2 disk mounted plow. I grew up with a 200 and a C-20 moldboard but I had no experience with a disk plow. I know you pull the stabilizer pins to let the moldboard float and I thought you would do the same for a disk plow. The area I needed to plow was small so I just left the stabilizer pins in. The disk plow worked much better with the pins in. It tends to pull too far to the left with the pins out. Do the disk plows not suppose to float?
noticed the same thing on mine.. she will jump to left when not right....noticed though with pins in i seemed to tear up back disc when hit some stumps,,may be instead of floating over. really dont know ...need to play more ..either way buddy that disc will do it...dewy
