Anonymous-0
OK got the metering drilled out to 0.031", no screeching etc, all works BUT it is really hot on the steel lines and the tank under the seat. I mean way to hot to touch with fingers. Is this normal?
It would sizzle spit on the tank.
It also seems to be a big jump in RPM when lifting with cylinder, big horsepower just to run the pump.
It had been run for about an hour in 70 degree weather. Fluid is the cheap stuff from Tractor supply, yellow bucket, 333 compliant.
Just wondering if I missed anything.
tx in advance
tx in advance
