lee little
I was able to get my 806 home Wednesday. I did not have time to do anything with it until today. It didn't run perfectly smooth so I thought I would tinker with it a little. First I replaced the rubber fuel line with a steel one. I ran it from the electric fuel pump to the carb. My manual hasn't got here yet but I don't think this was stock. This made me think some had a fuel delivery somewhere along the line. I also changed the plugs and did a visual on the points. Started it back up and pretty much ran the same,not as smooth as my 560 gas. I thought I would drive it a little and see what happened. After about 10 minutes it sputtered to a stop. I pulled the line off and just a small trickle came out. I blew on the line and at first dirty gas then a good flow. Hooked it back up fired it up and ran smooth as silk! Drove about 400 yards and sputtered to a stop again. Repeated previous process and got same results.Drove it back to the shop and parked it. Now my question is there a screen in the tank that is stopping up and am I going to have to pull off the tank to fix it? Thanks for any help/advice. Lee [Sorry post so long]
