52 SA Final Drive vs 56 Farmall 100
equeen
Will the left side final drive of a 1952 Super A perfectly replace the left final drive on my 1956 Farmall 100? Thanks.
I think they made some changes to the 100 finals to strengthen them for the fast-hitch, but otherwise I would expect it to bolt up.
They changed to the toggle style brakes in '53. I believe that required a change to the housing. If the Super A housing you are looking at is the early style, the brakes probably won't fit.
I would suggest going to caseih parts site or messicks's site and compare a few part numbers between the two models. There could be some part number updates and still fit but there may be some obvious differences like the brakes as Jim mentioned.
Dennis
