Farmall Cub 3-Point...
CubLover51
New User
Has, anyone known about a Farmall Cub 3-point Conversion kit? for my 51 Farmall Cub.
here's the link -->http://www.yesterdaystractors.com/Farmall-Cub_3-Point-Conversion-Kit_HK90.html
If, you know more about this and "IF" they made attachments for it please comment below Thanks Kyle.
had one from 1996 to about 2001 on a 1968 Cub
mounts good and works ok
I prefer a fast hitch
however for a three point it is good
limited by how much a cub hydraulic can handle
good luck
Ron
Here's a link to the operator's manual for that
particular hitch that will give you some more
information. Note that the implement weight is
limited to just 350 lbs so a person would have to be
careful when selecting implements.
Cub 3 point hitch manual
Plus, if you are thinking about a mower or brush hog type implement, the cub pto turns CCW, not Cw as is normal, and also at engine rpm (1800 full throttle), not the standard 540 rpm.
