Hey guys wondering if I could get some help on my Farmall H? I have a lot of questions about the electrical system. I thought the main problem was the battery, but after a new battery with a full charge it barely, if at all, turns the engine over and the Battery cables are actually getting hot enough to melt the wire casing. It has the 6v positive ground with a new 6v battery, new generator, new regulator. The ammeter is new but is not the 20-0-20 or D-O-D type. The wiring harness has been patched in several places. It has the original H switch with the original guts in it. I added a battery cut off switch when I thought the battery was draining.
when cranking the starter the volts drop down to at least half. Must have a short somewhere. I was hoping someone would be able to get me started and talk me through trouble shooting this tractor. Thanks
