Anonymous-0
Cleaned a carb on a H for a friend and it doesn't seem to run as fast as mine and when you idle it down it dies, where as mine just idles really slow. The tractor was all gummed up with varnish in the sediment bowl and when that was clean I could only get it to run on brake cleaner shot into the intake of the carb. So I took the carb off and cleaned. Runs now other than the speeds mentioned earlier. When and took another carb off for another friend to clean and he said his runs the same as the previous mentioned H, but his other one runs like mine does. So what am I missing. thanks chris
