You are on an IH board but your issues plague all makes. Most likely a exhaust valve is not opening creating pressure in the cylinder which forces gases past the rings down to the oil pan where the path of least resistance is the vent tube. The valve may not be opening due to being stuck, bent rocker arm, loose rocker arm, or other rocker assembly related issue.
