Opinions on disc
1legonutt
Ran across this disc at a local scrap yard. It's a 9 ft case in
pretty good shape my opinion is that it will be all my farmall
350 will want. I think I am gonna get it it's hard to find some of
this smaller stuff. Please let me know your thoughts
Rob
I pull a 10-ft Fast-Hitch disc with my 350 and it works fine. The disc you're looking at will have a lot more weight per blade and will pull harder but you still should be OK. You can always bump it up a bit with the wheels if you bog down.
From what I've seen a disc like that would have at least a $1000 price tag in many areas.
You got plenty of tractor for that. I pull a 14' Deere disc with my 300 in light soil. It won't pull that much in black dirt or clay. But in sandy loam its fine.
I would buy that disk. I think your 350 will handle it. Dad had one of those Case wheel disks back in the day it was in the 8' to 9' range.
Pilled it with a 430 case diesel of less hp than your 350. That case disk was a darn fine disc too. Made a wonderful level seedbed.
Iftractor struggles pulling it, you can usally cut disc down to make it smaller. Or simply remove an outside blade on front and rear on each side
Hey, what about those 2 plows? Looks like a #8 on the left. Please go back and check out the moldboards. If they look good and are not too far from Wisconsin they might find a new home. Do you know what the asking prices are?
LA in WI
I agree with other replies, looks good and should fit well on a 350.
Consider trying to save those two moldboard plows. You could possibly re-sell and make a little on them.
The plows are #8 s one is old 20s I think but worn out beet up and not complete not enough for me to be interested. The other is a two bottom hyd no 8 also not in the best of shape don't remember what the bottoms look like. I already have a two bottom no 8 I told them if they cut it up I would take the rear rim. This pic is not that good but it has the other plow.
Rob
