blade attachment for SC thru 230
I have the fast hitch attachment for the SC/200/230 blade that lets you use it as a grader blade. Does anyone seen one sell or knows what the attachment is worth. Thanks Ed
You talking about a rear blade, front or belly blade.
I believe you are asking about the item with the short fast hitch prongs that installs in the tractors fast hitch sockets which is used when installing the C-72 IH blade in the center or belly position between the front and rear tires. The item is called a fast hitch drawbar adapter to which the lifting arm assemblies attach to something rigid at the drawbar. That piece is hard to find if you would be looking for one but there is little demand for one as people who mount the blade in that position most likely already have one. The C-72 blade can also be mounted in front of the tractor which is far more common and it is not used in that case. It requires several other items for the front mount location which are also hard to find if you obtain a blade which had previously been mounted in the center position and some of them most likely missing. I saw one of those adapters on a trailer load of odds and end at a RPRU a few years ago and the person was selling items for basically an offer price even though it had a $95 price marked. As I recall it was still there near the end of the RPRU unsold probably because few people knew what it was and those that did already had one for their C-72's, Hal.
(quoted from post at 15:50:45 12/04/14) I have the fast hitch attachment for the SC/200/230 blade that lets you use it as a grader blade. Does anyone seen one sell or knows what the attachment is worth. Thanks Ed
I am interested in buying it from you. My dad has a Super C and has been looking for a blade and mounting hardware. He has the blade but it was missing the rear attachment hardware.
