Installing a FH on my 460.Using the hydraulic block for the FH from another 460 since all (3) of mine were double acting with the drawbar.
Put all back together and the block for the FH (far left block) does not seem to have pressure. When I move the other (2) handles you feel the pressure and feel them working properly (if an implement was attached).
There is oil coming from it to the rear, I did check that.
The only other thing I did different was on the middle block. The block that feeds quik-connects to the left. I removed and put plugs in the top since I will never need (4) quik-connects. By doing this, did I change or alter anything keeping FH block from working or is the left block just needing re-built?
Any help is appreciated - Thanks
