IAtractorKid
Hey guys! So I just finished going through the Zenith 13021 carb on my IH 606. Thing was full of rust, had a couple broken pieces and the float had two holes in it...can't believe it ran as well as it did. Anyway, got everything back together and started the tractor. Ran great but I have a steady stream of fuel running out; I'm going to recheck my float setting but was also wondering if that accelerator pump could cause this? It has three grooves for length settings, I didn't know that before hand so don't know how it was set when I took it apart. Anybody know which groove this should be set to???? The pump is in the upper left of the picture beside the carb to manifold gasket. Thanks for your help!
