IAtractorKid
Hey guys! Finally warmed up here so was able to work on the tractor a little. I warmed the tractor up and tried a mechanics stethoscope...can't hear a definitive knock with it, but can hear different tone in the center of the oil pan vs the outer edges. Everything else sounds consistent throughout. Not sure if the different tone is a bearing or just from the oil pump. I drained the oil, its black but looks fine otherwise; no metallic sparkle or metal filings. Can't get the pan off with the wide front on. Lowered it about 2", can't see much but what I can looks normal.
Any thoughts or where should I go next?
Thanks!
Thanks!
