farmall 200 hydraulic pump
R&W
what hydraulic pumps part numbers are interchangeable for a farmall 200 with a C-135 engine with a R&R pump?
thanks
Farmall 200 should have a 123 engine so if yours has
a 135 you may want to post pictures so we know
exactly what you are doing . I think drive gears
maybe different maybe other variants .
(quoted from post at 22:49:08 02/06/15) what hydraulic pumps part numbers are interchangeable for a farmall 200 with a C-135 engine with a R&R pump?
thanks
Kub.... is correct. If you have a C-135, it's an engine most likely from a 404 or something other than a tractor. As far as I can tell, the pumps from Super C (or maybe C) through 404 and 2404 are the same Pesco or Thompson pumps. the drive gear [u:9c473ad0fe]may[/u:9c473ad0fe] be different for the 135 engine.
