Hydraulic cylinder for 300 trip bucket
Sparky70
I was wondering if anyone has a source for replacement cylinders on old trip buckets? I have run a search but nothing came up. My cylinder is approx 66 inch long, 1.380 rod diameter, 2.640 OD barrel, 1" pins with approx 18" stroke (probably longer if worked properly). Seems like allot of wasted space on these old cylinders. Sorry, no idea what brand the loader is. Any sources would be appreciated, thanks
Surplus Center or Baily will be your best route for
a cylinder.Look up the correct size and order.You
may have to adapt the ends....
Sooooo are we to assume that you are talking about a International or Farm-al model 300 or a different make tractor? Also if you would/could post a couple pictures of the loader somebody will be able to id. the make & model of your loader. Need pictures to help you!
Armand
Hydralic Services in Spring Grove ILL, this guy is the best a repairing any Ram and he is also and antique tractor collector so he will give you a hand and advice tell him I told you to call him, his name is Mark 815/675/0077.
Armand
Cycl 66in long weith 18 stroke something dont add up to those figures. If you can find a cycl from them that will work there just wont be any. You will probably need to make some new mounts but a 18 or so stroke is not impossible to find.
