Delawaresurfman
Good morning, I see a lot of posts about relocating the ground strap closer to the starter and have a few questions.
I have a 51 TO30 all original 6 volt system.
Does anyone have pictures of the relocation?
Should the ground strap be mounted to the starter mounting bolt ? If so do I need a longer bolt?
Is a 00 size the same as 2/0 as that's what I see listed on most sites.
What size ring on the wire is needed if indeed I can use the starter mounting bolt? I see 2 different sizes available.
Should I mount it to another location on the block instead of the starter mounting bolt?
Thanks, John.
Thanks, John.
