6.50 x 16 vs 6.00 x 16 Front Tires
guysradios
New User
I came across a set of new 6.50x16 tires cheap cheap that I want to use on my TO 30. Has anybody used them in place of the standard 6.00x16 on the front of there Ferguson ? Any issues? They look about a half inch taller, but not much wider than the 6.00s. Thanks
i have 6.50-16 on my to 20, i like em
Smother ride as more surface touching ground. And should have no problem with sidewall clearance unless you are in heavy mud then you would also have that with the 6:00 tire. I had a 30 years ago and would not mind having one now but no use for anouther tractor.
picture of my TO35 with 600-16's on the front.
am sure the 6.50 would not make that much difference.
if they are cheap go for it.
