Rear Center Discs
Tim PloughNman Daley RIP
Does the TO-35 use the same 28" rear center discs as the TE/TO-20's and 30's? I know the 28" FORD 8N center disc will swap out on the Fergies and vice versa so I assume the 35's were the same as well.
Tim Daley(MI)
Some of the early 20's and maybe the early 30's had different loop style. Where the bolts goes thru. They were all 28" and will work. The loop is just different. I have one center which is early and can take picture if you need it.
I'm talking about the center discs, not the rims. Loop style rims were/are aftermarket I believe. I do know that the early Ford-Ferguson 9N used 6-loop style rear rims, before the Hat Rims were introduced. These were only used on maybe the first 700-8-00 units, maybe less. I don't know about Ferguson, but by then (1946) I think they were using hat rims or something similar. The center discs are interchangeable and that is what I am posting about.
ORIGINAL FORD-FERGUSON 9N LOOP-STYLE REAR RIM:
Tim Daley(MI)
