Ferg Cult stabilizer wanted!
Lynn Patrick
Hi! I'm new to this board, usually hang around the Ford sites. I have a Ferguson 2 row rear cultivator ("TYPE - NKO 21") that is complete except for the stabilizer bar. If I'm not mistaken it is a flat vertical bar w/a "tooth" on the bottom?? Any hope of finding one somewhere near eastern Iowa?
Thanks for the help!
I just googled "Ferguson cultivator" & it appears there were both styles, so I guess I would accept either.
Thanks!
Tractor Supply should have it. Farm Auction might be something to check. You can make
it. I always use one on each side. I think it is 32 inches center to center on hole.
Lynn,
I think this guide bar is what you are looking for, should be many laying around somewhere, however metal scrappers have cleanup a lot of the old scrap metal.
this is an older Ferguson two row cultivator, I just use the guide bar as a brace to hold the machine up when stored, I take it loose when I use the machine.
I took this picture for you as it does not look like it would be that hard to make a guide bar, note it has brace bars from the cutter knife back up to the rear cross frame bar, you would need these bars
later they when to a guide disc blade, why I do not know either would work
I use this old cultivator frame as either a hiller or bar out plow, works good,
Thanks Guys! Somebody sent me a Cgslst ad w/everything I need! Now if he were just home when I called???
Thanks again!
