Brake shoes for TO-20
lbauco01
Looking for help getting brake shoes for this tractor. I ordered some online specifically stated would fit the TO-20, but when they came were too small. This tractor has a brake drum of 14 inches and liner of 13 1/2 inches. Does anyone know where to order these or where to get the shoes re-lined possibly? I've got the MF dealer looking for parts now, but its not looking hopeful.
Info from Parts Book:
Bob.........
I typed in ....Ferguson brake shoes 830 537 M91..... on the Internet and several suppliers names were shown:
I guess you're sure it is a TO 20? I had a TE20 and it had larger drums than a TO20. The drums you mentioned sound like the same size as a TE20. I couldn't fine shoes for the TE20, but you can get linings for them and rivet them on yourself, not hard to do. I might be wrong, but believe this is right.
RJfromGA, I believe you hit the nail on the head. I have ordered parts for this tractor as a TO-20 that worked in past, but this brake issue has not worked out for me. Unfortunately the tractor is so old it has no identifying serial number or other ID that helps me out. It does appear from my research online that the brakes on this tractor are consistent with the TE-20. I did find the liners to order from the parts dept at YT, so maybe that is the best way to go. Thank you for the help.
You might want to order that rivet installing tool also, it makes it a lot easier. The least expensive one on that page will work fine. There's a few ways to tell a TE20 from a TO20. If the transmission case is made from an aluminum type material it's a TE20, that's just one way to tell.
