292 oil pan removal
jesse CA
Hello All
Is it possible to remove only the oil pan with out removing the engine,front axle assembly or any other surrounding parts
I just finished removing the oil pan on my 202 so I discovered that it is possible to remove the pan without disturbing any thing else.
I needed to remove the oil pan due to the oil drain plug having stripped threads,finding a loose 5/16ths nut and finally black oil sludge in the bottom of the oil pan.
