Ok the last set of pictures. First a list of things done to the tractor.
Engine:
Crank was turned and new bearings, cylinders, pistons and rings. The valves were ok just reseated, new gaskets, water pump and radiator hoses, the radiator was ok just cleaned and painted.
Fuel: Tank cleaned and rust converted, carburetor replaced with overhauled original, original oil breather found and installed, new metal fuel lines and fuel shut off valve.
Steering:
Replaced front wheel bearings, spindle bearings, front and rear drag link ends, one front tire(the rest were ok for now), rear sure seals installed and new brake shoes. Rear bearings were ok just cleaned and reinstalled.
Hydraulics: new piston and rings, everything else just cleaned, honed and reinstalled. A new gasket
Dash:
New steering shaft bearings, steering wheel, chrome shaft cover and chrome nut. New ignition switch(toggle type) new gauges and new light switch.
Electrical:
New points, condenser, coil, plug and coil wires, plugs, overhauled generator and starter (6v), new starter switch and all new wiring harness(home made)
Lights:
Replaced light housings with non original and converted to 6v. New hood wings, a new light switch for rear work lamp, new rear running light and license plate holder(modified to resemble original) as well as a new wiring harness(home made) and wiring conduit.
Sheet Metal:
New grill. Hood, fenders and hood legs were all stripped, dents filled and painted. New front and side emblems. Seat replaced with correct type. The tool box under the hood as well as the battery tray were missing and originals found and installed.
Misc: Replaced oil filler, radiator and fuel caps with original type. A new engine id plate installed and hood pivot bolts put in. New radiator and fuel tank pads installed as well as the rubber dash bumpers. A new muffler put on. Countless nut and bolts either cleaned or replaced.
I know I am forgetting some stuff but you get the idea. It was a lot easier to find replacement parts for this than it was in 1997 when I restored my Dad's tractor. Thank God for the internet.
Lights
new steering wheel
new ignition switch and ammeter
New oil pressure gauge and light switch. I know the light switch should go on the left side but since I wasn't using the red voltage light it looked like a good place to put it. It also made it easier to wire in the light whith it there.
wiring harnesses
Battery ground and light harness. I grounded the lights with the battery ground.
More lights wiring
new seat
hood emblems
The finished product.
Learning to drive for the shows
look out, you have competition
