I posted a while back about the 3 point lift
on my 63 ford 4000 having issues being jerky
while lifting a post hole digger. The lift
always had plenty of power but was jerky.
Tonight I drained the fluid and found it was
contaminated with water. It was a very
light brown chocolate milk color. While it
was draining I pulled the small cover off of
the top plate. I had bought a top cover
gasket kit and figured I would at least
replace the small block off cover o rings.
I replaced them and here is where I think I
may have screwed up. There is some sort of
valve under that cover. I unscrewed the cap
that holds 2 springs under it thinking maybe
there was another seal there. There wasn't
so I put it back.
I then refilled the fluid and started the
tractor. The lift didn't work at all so I
pulled the Allen plug on the pump and bled
it. The lift now raises but very slowly and
has now power. I can push it back down by
hand. When I shut the tractor off the lift
instantly drops back down. It is like there
is a one way valve not allowing pressure to
build or be retained. I don't see any leaks
coming from the cylinder through the fill
hole.
What should I check next or what did I screw
up? I doubt an internal leak since it
worked before. Any idea what that valve on
the small top plate is for?
Keith
so I put it back.
hole.
Keith
