Starter switch used on 8N, Ford Jubilee, and an 871 ford diesel I just got started. how does this switch work: Tractor has to be in neutral I know . one wire goes to the switch. Is this wire hot? Will check wire on my 8N and Ford Jubilee later. Replaced switch on the ford jubilee as person owning it before me had put in a push button switch
Just got my friends 871 ford diesel started. Fixed the manifold pre heat switch with a push on /off switch from napa Maybe to push button switch in the transmission is broken
