I was asking about the broke 7/16 bolt on the engine when I was mounting the 132 CI engine to the engine stand.
Maybe I should just skip removing it from the block as it may be more trouble than it's worth to get out and the engine mounts on 3 bolts with no issue on the stand.
How many bolts are required between the engine and trans when putting the tractor together?
I have 2 bolts at like 11 and 1 o'clock. These are 7/16.
I have 4 large bolts, like 9/16. 2 on each side and of these 2, one is to the block and one is to the stiffner plate between the engine and transmission. There were no bolts in the additional 7/16 holes when I took it apart....should there be? These are at like 5 and 7 o'clock? I'd use them if there and tapped. I can use the one side that doesn't have the broken bolt. Please advise....maybe working for days on one broken bolt isn't really time well spent. Thanks, moday
