961 carburetor parts
AllisG
Installing my carburetor after replacing the starter on the tractor i managed to crack the front manifold mount to the point that i cannot tighten down the carb without air leaks. Does anyone have an idea on how they would fix this? is it possible to weld a washer as a fix or does anyone have parts carb for the 172ci motors?
You or a shop should be able to braze it back together. I don't remove the carburetor to remove the stater on my 901, just the oil filter.
Post a picture, but yeah.. Brazing or cast rod welding should work.
Depending on what broke, "maybee " a washer pinch arrangement.
Not the same carb, but here's one option for repair.
The nut was used to hold the bolt up tight and straight.
I may have the parts you need too, but not all 172 carbs
are the same. What model carb do you have?
