I want to start out saying thank you for all the useful information here on the site. Everyone as really helped me with this job and feel silly that I took lid off, put back on and not working right still. Sounds like I may have to take it off again.
[b:23445d94e5]Work Done[/b:23445d94e5]
I started out having a weak lift and wouldn't go up all the way. It would get implement off ground, but didn't lift to full potential. So, I pulled off the lid, changed piston, o-rings and cam follower pin (really worn). I didn't get in the valves as did not have the tool/puller to pull them out.
[b:23445d94e5]Problem[/b:23445d94e5]
Put everything back together last night. Started the tractor and let it run for a few min. Engaged the touch control lift and nothing happened... then 20 seconds its started lifting. It lifted all the way up and I was like YES!!!!!
However, once got all the way up, it started hiccuping. Would bounce down a 1/4 inch and then go back up... this continued only on the lift not on the lower. I didn't get to mess with it too much more, as was late. Nor sure this would do this with implement or hold and implement. What would cause this? Could this be me putting the piston o ring on incorrectly? Air in the system? It wasn't doing this before.
