running boards for 1984 ford 2810
Blue0182
New User
New to this board and Ford -I just purchased a Ford 1984 2810 that needs some work, am trying to locate new running boards both right and left. I can't see to find them anywhere have found 2610 and 2910 boards.
Does anyone have any suggestion or is it easy to modify any other size to fit.
I'm not real familiar with those models, but Ford was good about using the same parts on different models. Since they are similar
in both age and size, I bet they would be a direct fit.
(quoted from post at 17:54:31 02/20/18) Any of these look like yours? [b:4a68d648c8]CNH[/b:4a68d648c8]
It does look like the same except that the right side has a hole where the brake cable goes through see attached picture
(quoted from post at 21:45:55 02/20/18)
(quoted from post at 17:54:31 02/20/18) Any of these look like yours? [b:8cac163aef]CNH[/b:8cac163aef]
My eyes ain't what they used to be Blue. That picture looks blurry to me.
Royse my bad, the picture is indeed blurry will get a new one when I can get to the machine on Thursday or Friday.
Thanks for the help .
This the start of a new project have a couple of other Kubota,s and wanted to try something different .
I'm pretty sure they (NH) used the same picture that
they already had from the 3000's. A 3000's brake
lock was down on the running board, and had the
bracket shown to hold it. The 3600's moved the
handle up onto the transmission housing, and
eliminated the bracket on the running board, leaving
just the hole.
A 3000's running board could be used; you'd just run
the rod for the brake lock down through the bracket
and hole.
Left foot board C5NN16451D
Same as used on 3000,3600, 3610
Right foot board E9NN16450EA
Same as used on 3610, early 3930
This board is different from the 3600 foot board because it has the foot throttle bracket welded to the foot board and also uses a different style of foot throttle.
I ran into is issue when swapping on a set of 3930 foot boards onto my 4500.
According to the parts site the 2810 used the same foot rests as the 2910 as they both used the same rear axle with the double reduction gears and wet brakes. The foot rests for the 2610 were different, as it had the smaller rear axle with drum brakes and without the double reduction gears.
