perryjosh64
Folks i recently had to replace my radiator on a 64 Ford 2000 gas tractor. My old radiator had the drain port on bottom of lower hose metal connector. New radiator has drain port on the front bottom portion of radiator as you are looking at it. I assumed like a lot of aftermarket parts it was just a case of part is made to fit multiple models and such. However when i got everything bolted on i noticed the front hood latch rests on top of radiator? Question is it supposed to do that? I dont recall if old one was the same way and just worried over time latch will rub/poke hole into radiator? I did turn around and put a piece of inner tube between hood latch and radiator to buffer it.
