No, that just makes it less valuable.
Look on the transmission case just behind the starter, there should be 3 rows of numbers and letters that were hand stamped on the flat area near the top of the case.
no number stamp where you said,but did see on the new holland stamped on the main frame under the seat but the hood has ford and the front emblem on the cowl looks like new holland insignia
Should look like this.
Top row is the model Id, on this one its a 5030 Diesel with Ind pto and 16x8 shuttle trans.
Middle row is the production date,
3 is the year, 1993 for this tractor
E is the month, May
05 is the date, this tractor was built May 05 93
Bottom row is the serial number which on this tractor is consistent with a tractor built during the 93 production run
Does you fuse box look like this
The fuse locations are labeled under the lid
This one is from a 94 3930 with 8x8 shuttle, it only had two relays, their location is numbered under the lid but you have to look in a owners manual for their actual use.
