ShermanPowerDigger
Hi folks, I have an old ford tractor with a loader and backhoe and am trying to locate parts, catalogs with exploded views, manuals, and the numbers I found stamped into the metal behind the starter are 82I. It is a 4 speed transmission so I was not expecting the 2. The "I" is presumably industrial.
It has a ford loader model I9-201 and a Sherman digger model 1168. I pulled the front pump and shaft but still need to get to the crank pulley to get to the stripped out part. The shaft I pulled had tapered splines, from what I've been able to find online it looks like the splines are not supposed to be tapered but straight. I won't know for sure until I can pull the other end but any help finding exploded view diagrams would be greatly appreciated.
This old tractor has good sheet metal and last time I had it running was sweet until the front pump shaft stripped out some gears. Someone has added an alternator in the past but otherwise looks all original.
Any and all help is appreciated.
