TractorLinks.com
Show Parts for Model:
OT - Poulan chain saw woes!
Lynn Patrick
07-12-2018 14:03:28
Trying to get my son's Poulan Pro 36cc saw running. It starts good but dies when you pull the throttle. If you throttle up slowly it will accelerate, but will not stay running at higher rpm's. Any thoughts???
Lynn Patrick
07-13-2018 08:54:02
 Re: OT - Poulan chain saw woes! in reply to Lynn Patrick, 07-12-2018 14:03:28
Some good suggestions! Won't get back to it 'til next week, but will see if any help!
Thanks Guys!!
KV Bruce
07-13-2018 07:19:49
You are getting some very good ideas here, I have done most of them on my poulan saws. Before you take it apart try enriching the LOW idle screw 1/4 turn. An Echo salesman told me that and it fixed the problem. My 85 hp Mercury outboard always sputtered when I advanced the throttle quickly, opened the LOW idle 1/2 turn and no more sputtering. You can find the complete tune-up kit on amazon for the Poulan saws. Fuel line, bulb, fuel filter, air filter and spark plug. Pay the extra $$ and get the ethanol-free gas.
Indiana Ken
07-13-2018 05:53:19
Might check the lines going to/from the primer bulb. My Poulan is one of the green models (not a pro), replacing a loose fitting line corrected a similar problem on mine.
pomester
07-12-2018 18:22:26
you can't go wrong replacing the filter on the end of the hose in the fuel tank -
rvirgil_KS
07-12-2018 17:19:23
I had a green Poulan that would run but not rev up like it should. Pulled the muffler off and cleaned it out. There were a couple of small slits where exhaust came into the muffler so I took a screw driver and enlarged them slightly.
880DB
07-12-2018 14:13:30
Sounds like an air leak! Base gasket, intake boot, impulse line, fuel line. Just a few things to check.
