I want to stop my rear axles from leaking differential oil onto my breaks and wheels so I need to replace the rear seals. I wondered if it would be acceptable to only replace the inner seal on the trumpet by pulling the rear break/bearing assembly/axle out and just replacing the inner seals.
I don’t have a torch to cut the bearing collar off or reinstall it so I was going for an easy way out and only replace the inner seals.
I was wondering if this procedure explained here
www.external_link.com/20-ford-new-holland-tractors/442290-brake-shoe-replacement-800-series-ford-tractor.html
is correct before I started this chore?
If this procedure is correct I will start collecting parts as I intend to restore the tractor to working order.
