1962 DEXTA petro oil press sending unit.
Anguspg
New User
I was wondering if anyone could help me with the location of where the oil pressure sending unit should be on my 1962 4 cylinder petro engine. The 87mm engine I believe it's called. I need to rebuild this poor neglected soul and much is needed. I just finished rebuilding the fuel pump from a kit put together by Hal Houghston and next the fuel tank and oil pressure sending unit and gauges.
Bump, come on guys , I need this info to work on this tractor, it has been butchered a lot and will need info to put it back to oem.
Okay, this is a temporary set-up that we used. I have another one that is still stock, but
no pictures just yet.
You can see where the temporary oil pressure gauge is fitted.
(reply to post at 10:25:00 12/03/17) [/ I've removed the 7/16th plug and couldn't find an adapter for the 1/8 pipe thread oil switch, so I drilled and tapped the orig plug to install the switch.
