Transmission and rear end fluid
Would that work in trans A and trans B?
What would happen if you put the
universal tractor
transmission/hydraulic fluid in the
tractor?
Does the 15w-40 work best?
How much does it take to refill the
trans A and trans B
Thanks for the advice and information
5 gal for transmission and 10 gal for rear end will be close to full level.
15w40 will be good, never seen universal t/h fluid recommended for any Majors.
In my multiple Dexta tractors, I use hydraulic fluid oil, mainly because I have remotes. When I use my dump trailer, hydraulic third arm, mowers and other stuff with hydraulics, I don't mix fluid if I use my 1000 series Ford, etc.
Wayne
