(quoted from post at 01:22:22 11/02/21) Sounds like your pump is worn, is that the pump with the round tank
driven by a belt and mounted up on the cylinder head?
(quoted from post at 09:04:53 11/02/21)(quoted from post at 01:22:22 11/02/21) Sounds like your pump is worn, is that the pump with the round tank
Thanks for the reply, I'll check today. Is it possible to include a photo on this forum?
(quoted from post at 03:55:03 11/03/21) If it works when cold and not when hot, it says pump worn out to me
98% of the time.
(quoted from post at 08:04:33 11/04/21) Those pumps were pretty common on trucks and tractors but it is
nearly 60 years ago now. May be best to look for a later belt
driven pump and adapt it to fit from a breakers yard. It is not a
high pressure or high volume operation.
(quoted from post at 08:11:38 11/04/21) Google Steiner's Antique Tractor Parts as they are offering repair kits for a Power Major pump which is the same.
(quoted from post at 09:59:14 11/04/21) I would very much doubt the PR Valve is the problem from the
symptoms you describe.
