filter source
Tim(NY)
Does anyone have a good source for oil and hydraulic filters? I need them for a couple of older ZTR's (Bad Boy and Husqvarna). I tried googling but couldn't find anything I could search to my models.
If you are just searching for Bad Boy and Husqvarna filters, You are wasting your time. For neither Bad Boy or Husqvarna are into the filter business.
Try searching again by googling the Engine and Hydro manufacturer names.
Quick search for Kohler engine oil filters gave me 2,480,000 results in less than 1 second.
Got 2,860,000 results (0.89 seconds) googling just Hydro Gear oil filters.
Most likely could have gave you the part numbers and good places to buy filters in less time than it took to type all of this if have known the makes of the engines and hydro's.
The Husky has a Kawasaki 18H FH531V engine, the current oil filter is a Rotary 12884 (replaces Kawasaki 49035-2078); I couldn't match up either of those. The trannys are Hydro Gear, the current filter is a Stens 120-380, couldn't find that either. The mower is early 2000's; so old that it does not have a 9 digit SN starting with 9, like the dealer says all Husqvarna's should have. I was able to match up the Bad boy oil filter, and I can't find a hydraulic filter on the machine or the online manual.
kawasaki oil filter you want is 49065-7010. the bad boy unit may be unit that does not have external filter that screws on, very common. do nnot worry about it. if it is smaller model with hydro gear tranny the filter is inside the case. otherwise tell me which model husq you hav and i will have the hydro filters for it on shelf also if need. good luck
