Adjusting valves on a Kawasaki
Russ from MN
Location
Bemidji MN
What are the chances that the valves should be adjusted on our 15-42 Husqvarna mower? It has the V-twin 15 hp Kawasaki with 532 hours on it. It runs fine, but I have time to do some maintenance, and I have it in the heated shop. What should they be set at? Thanks!
with 532 hours, Its probably time for a valve adjustment. I bet someone has the valve specs on the internet if you search for it by the engine model.
