Looking for Cub Cadet 1000 belts
You might check with the owners of this website first.
Case/IH has one.
Then there's https://www.onlycubcadets.net/
(quoted from post at 15:13:39 09/03/18) You might check with the owners of this website first.
Case/IH has one.
Thanks for your reply. Not sure what you mean about checking with the website owners, but I've been to the occ site and couldn't make sense of the belt chart provided by the admin.
(quoted from post at 15:53:19 09/03/18) cubcadet.com
partstree.com
Wasn't able to come up with anything with either, but I called parts tree and they told me I need the tag number off the mower. That appears to be missing.
The tractor is a Cub Cadet 1000 serial# 2050550u624996, and the mower is a 38" deck with a 20" blade in the middle and two 10" blades on the outsides. I need the belt that goes to the pto and the center spindle. (old one is bent).
Not sure how to proceed without the serial number of the mower.
(quoted from post at 01:27:04 09/04/18)
partstree.com
I just went to cubcadet .com entered your info and came up with part number 490-489-R2 eezy peezy to find it.
P.S. no serial numbers or tag/model needed there either.
You do have to open sub folders to whittle down the search for what you want.
Sometimes you run into a dead end. Then you have to go back up a folder or two and look in a different folder.
timcasbolt:
According to the Cub Cadet Belt Reference Guide and the IH CPE-2B Parts Manual, the correct belt for a Quietline 1000 with a 38" mower deck is [b:25abd38a31]IH-473462-R4[/b:25abd38a31].
Go to ebay and enter "Stens belts Cub Cadet 1000".
Or goto Stensbelts.com if you know the belt length and width.
JB
(quoted from post at 22:16:41 09/04/18)
partstree.com
Thanks for your help.
