steelwheeljim
I just picked up a model 12 Hydro Drive with Hydraulic lift at an estate sale. I got it running with little effort but it will run for about 5 minutes and die. It will not start back up right away. Walk away from it for an hour, then it will start. I'm thinking the coil gets hot. I have no experience with the Solid Stand Ignition. Any advice?
Also, the hydraulic lift does not work at all. Where on the belt driven pump in the front do you check/add oil?
Thanks.
Thanks.
